delagina
- Sep 18, 2010
- 1,008
I was asked to do a lifting plan for a pipe valve. The valve has 4 lifting eyes so it was simple. I just had to compare the weight of valve vs the capacity of crane. And also add appropriate rigging/sling.
Client asked for another lifting plan drawing. Valve was transported in horizontal position and they need to lift this in that position for transporting to site and also to turn this valve to vertical position.
I called the manufacturer and asked. He was helpful and told me how they have done it in the past. Basically they just used 2 lifting eyes and choker on the pipe connected to the valve.
Don't know why client just don't call the manufacturer.
I believe they also want a lifting plan drawing that my company can produce.
Now since I wont be using the all 4 lifting eyes on some lifting instances, I want to protect myself by adding a disclaimer on this drawing.
Can you comment on this disclaimer:
Lifting plan drawing is just for recommendation.
Contractor must verify with manufacturer if the valve is being lifted on locations other than on four (4) lifting eyes of the valve.
Engineer of record is not responsible for damage during lifting.
