I have read that by multi-staging in air compressors or turbochargers,(allowing the air to pass through intercoolers between stages) returns the air to its original temp. and brings it compression (P-V) curve closer to that for an Isothermal operation. I assume that without intercooling the operation would be Polytropic. Is it correct to say that in an Polytropic process some cooling applies, therefore, somewhere in between isentropic and isothermal, real compression procession processes are generally polytropic in nature. The cooling would be the heat given of to the surrounding area and carried away with the compressed air. In an Isothermal process maximum cooling occurs and in an Isentropic process cooling occurs during. I have read that in an Isothermal process the temp. remains constant and in an Isentropic process the entropy of the working fluid remains constant. Can you please clear this up for me? THX.
