distance between gas pipe line and sewagw pipe line
Raajibb
1
hello sir, good afternoon everyone , i wanted to know what is the safe distance in underground crossing between gas pipe line and sewage pipe line? with some evidance(pdf) . can you help me?please
Err , not with that level of information.
"Safe" is in the eye of the beholder. The gas pipeline owner will want the separation to be as big as possible.
A lot depends on who is there first and what rights they have in each countries laws and regulations or land rights.
Typically you see distances of between 0.5 to 1m separation, but it is very variable.
Some more information would help a lot.
As LittlInch mentioned, it can vary widely by jurisdiction and utility owner. (A quick Google search yields as small as 0.5 ft. and as much as 10 ft. between gas and gravity sewer).
I suggest starting with researching local jurisdiction code and if that does not provide a specification, checking with the gas and sewer utility owners.
Gravity sewers yes, "forced mains", i.e. pressurised shit - usually laid at the 0.9 to 1.2m cover mark and level with the ground.
But the OP needs to define "safe". Safe for who? How "safe". It is a meaningless set of words at the moment.
The standard 300 mm safety distance used to place natural gas pipe away from sewage pipeline facilities needs to be abstracted to consider accidental damage and provide a safety buffer to the natural gas pipe.
