loktinl
- Mar 4, 2011
- 8
Hello all,
I am in the process of designing a custom collet to grip thin wires for a biomedical engineering project. These wires are around 1/16" thick and the collet is around 1.5"long and 3/8" thick at the largest part. What I am wondering is whether there is any heat treating process that can bring this 440C collet to ~58HRC without distorting the through hole diameter by more than 0.0005". I am assuming this would be dependent on geometry, mill specs, tempering procedure, etc. If there isn't, I guess I'm going to have to resort to wire edm to get the hole to size afterwards. There is no way to grind such a small hole correct?
FYI, the exact tolerance of the through hole has not been set yet. Of course, it would be moot to tolerancing this hole to be +/- 0.0001" if the wires it accepts vary by 0.001". I'm just kind of curious whether drilling the hole before heat treating would be acceptable or do I need to get the hole wired. Moreover, Is grinding necessary for a part this size? What range of distortions can I expect?
I merely have novice understanding to the lore of heat treating, so if there are some old timers who could chime in, I'd greatly appreciate it.
Thank you,
loktinl
Thank you,
loktinl
