Distribution of Lateral Forces 2
GalileoG
467
I have two different lateral force resisting systems along my N-S direction of my building. On one end of the building, I have shear walls, on the other, I have concentric cross bracing. I'd like to analyze and distribute my lateral forces without the aid of an analysis software. Usually, for shear walls, I would distribute my lateral forces according to relative stiffness. However, I have no clue how I can go about calculating the relative stiffness of a steel braced frame? How do I determine how much goes into my braced frame and how much goes into my shear wall?
Is it enough for me to assume a beam with supports placed at the location of my lateral system, and the resulting shears would be the force that my LFRSs will experience? I don't like this method at all, but its expediency is very tempting.
Any input is appreciated.
Clansman
"If a builder has built a house for a man and has not made his work sound, and the house which he has built has fallen down and so caused the death of the householder, that builder shall be put to death." Code of Hammurabi, c.2040 B.C.
YS
Did you get chance to skim through the spreadsheet? Any suggestion.
Zee
just to recap and agree with other.
metal decks are flexible diaphrams.
virtual work must be used to determine stiffness of braced frame by hand.
