hd2000
- Mar 1, 2012
- 13
Greetings all, was normally browsing here as a guest but have now decided to join this great group
I have a problem in a distribution network I maintain. It is in an area with:
Main 33kV D-D step down to 11kV sub-station(fuse protected both sides HV & LV)
Then 11kV outgoing auto-recloser (1 feeder)
Then multiple 11kV/0.4 D-Y transformers on the single feeder.
In this area we have constant blowing of ONLY yellow phase HV fuses on the transformers, sometimes even on the main 33kV (about 1 a week) on different TXs each time without a set pattern
What could be the possible problem in the system to cause this? The main 33kV TX has been changed several times also.
