Div 2 Part 5 (Design by Analysis) applicability to Stiffening Rings around a Vessel
Vicker85
31
Hello All,
I am doing Static Elastic Analysis for internally pressurized vessel which has stiffening rings around it. Note that this is not exactly a PV and these stiffening rings are not exactly for FV loading. I am using Shell Elements to model the entire geometry.
I have high stresses at certain locations at the junction of Vessel Body and Rings when internal pressure is applied. The high stresses are on the Ring essentially.
My question is : Can we categorize stresses (Pm, Pm+Pb, P+Q) here and compare against code allowable for protection against plastic collapse? if Yes, and if we are to apply Stress Linearization (although linearized stresses Pm, Pm+Pb are available for Shell Elements), how would we choose SCL for these areas of Ring to Vessel Junction ? Can we apply the same idea of that for a Nozzle-Shell Junction ?
" this is not exactly a PV and these stiffening rings are not exactly for FV loading "
Can you show us a screenshot or a drawing or something ?
Are these insulation support rings or something ?
MJCronin
Sr. Process Engineer
Thank you for you reply. I am sorry but i cannot share any pictures here :(
However, let me try to explain the construction:
I am analyzing a high pressure steam sparger system for stresses. So, this long sparger pipe (assumed as a PV) has small orifices located longitudinally. The orifices are only on 45° circumference of the pipe! To re-direct the high velocity steam, there is a 90° 'curved hood' - all along sparger length. This Hood is part of the sparger assembly. This Hood is connected to the sparger pipe via plates at certain distances - which in my question i have refereed as stiffening rings.
Again, apologies for making this description in absence of drawings etc.
Please let me know if the description is not clear!
Please read 5.2.1.2 and 5.2.1.3. Your answer is in there.
