circuitmangler
Computer
Hi everyone!
I'm sure most people are familiar with the hand-held LED
tester boxes that have come out on the market recently,
e.g. the ones that look like this:
For a while now I've contemplated how easy it could be to
make one yourself with an emphasis on doing it cheaply.
I've come up with a design, and I'd appreciate any feedback
you may have.
Version 1 - the el cheapo version.
This version just uses a single op amp but it can only test
one led at a time. The schematic can be found here:
To test the led at different currents, just connect it
between the op amp output and different resistor values.
Version 2 - The multiple LED version.
This version just uses one op amp per LED circuit, so to
duplicate the LEDtronic's device I'd need 11 op amps for
the top row and some more for the bi-color LED section.
Alternatively, I could use voltage regulators (such as a
LM317, etc.) to create constant current sources.
So -- it seems I need to find a cheap source of op amps
and/or voltage regulators that can source, say, 50 mA.
So here are the questions:
- Will the LM324N work for this? It's a quad-packaged
op amp that, if I read the datasheet correctly, can
source +/- 60mA (is that per op amp?). Also, I can get
them at glichbuster.com for $0.27 + $1.95 shipping.
- Does anyone know of an alternative op amp/voltage
regulator which is more cost effective?
- Is there another design which could cut down on the
required components?
Thanks in advance for any comments and suggestions!
cm
you may have.
cm
