Burunduk
- May 2, 2019
- 2,513
Y14.5-2018 8.4.1.3 Derived Median Line Straightness said:When the straightness tolerance at MMC is used in conjunction with an orientation or position tolerance at MMC, the specified straightness tolerance value shall not be greater than the specified orientation or position tolerance value and does not contribute to the IB or OB of the position or orientation tolerance. The collective effect of the MMC size and form tolerance produces a VC, OB, or IB resulting from the form tolerance but does not affect the IB or OB created by any orientation or position tolerances on the feature.
Why is the above rule of not specifying larger tolerance for straightness than for position/orientation applies only to DML straightness @MMC & Position/orientation @MMC, and does not include DML straightness @RFS & Position/orientation @MMC?
I think that if DML straightness @RFS & Position/orientation @MMC is applied the size of the unrelated AME may be greater than MMC size, however we wouldn't want it to become greater than the VC for Position/orientation @MMC, since we want the surface of the cylinder to be limited by the VC gage, without any unrealizable form allowance - same logic as for not wanting the VC for DML straightness @MMC to become larger than the VC for Position/orientation @MMC that will limit the surface anyway. Is this not the guiding logic?
