does any body know how you import
daveatpressac
1
does any body know how you import a reference image (jpg or bmp) into AutoCad, so that it can be used as a guide for creating the drawing.
I think you can resize or scale a raster image only. If you need use snaping to image's objects, imported *.wmf lets to do it.
If you just need the basics of importing, go to INSERT >> RASTER IMAGE or you can do a copy and paste into your drawing. You can then rescale the image to the size you need.
Dude,
BorgUnit is right ... [wink]
Just to add to that note ...
Make sure ...
imageframe=on
If this is off, you won't be able to manipulate the iamge.
Hope that helps. [spin]
[angel]
