Does anyone know how to make customized datum control frame in SW?
E-stone
21
This is the sample drawing:
It seems that SW does not have options to put something like [z,u,v]. Does anyone know how to do it?
I also tried to put an arrow on the drawing using notes, but there was a frame, how could I get an arrow only?
Thank you for all the help!:D
E-stone,
I do not have SolidWorks in front of me here. Those boxes labelled Primary, Secondary and Tertiary should accept whatever text you type in, including the brackets and lower[‑]case text.
What GD&T standard are you working to? The "[z,u,v]" makes no sense to me. Probably, you should not be doing this.
JHG
E-stone,
Attach the arrow. Type a space in the text box.
Problem solved.
JHG
This use of coordinate system components within the Feature Control Frame was added in the 2009 version of ASME Y14.5. It can take a while for software developers to catch up.
Hello JHG,
Thanks for the tips. I got the arrow and the customize datum control frame. I always type only one letter inside. Mind blocking.
However, this customized datum control frame is in the ASME Y14.5-2009.
Estone
