Does anyone know Steam Tracing Leak test(air) pressure
FatvengersKR
Petroleum
MX
Good day!
I am preparing steam tracing test.
ASME 31.3 said it is okay with in-service test. but owner want to take test with air.
therefore it may proceed with leak test with air.
but i dont know how much pressure is correct.
operation pressure is 3.1 kgf/cm2 and design pressure is 8.7kgf/cm2(max)
if i adjust 1.1times than design pressure, i think it is too much and may tube could not afford it.
please answer to me.
tube size is 1/2" SUS tube.
thanks
So you think a pressure just over the design pressure is "too much" ??!!
Why? This is complete nonsense.
1/2"tube can withstand much larger pressures.
The corret procedure is air pressure, at some grams (150/200) above the atmmosferic pressure and soap test all the welds.
@0707
Where did you get this idea?
