Good day ladies and gentlemen.
I recently stumbled upon a case where a part (low carbon steel) was cold formed from plates with a resultant strain of more than 5%. The part was therefore subject to heat treatment, but in ASME VIII Div. 1 I cannot find anywhere that normalization/annealing is required, only post-weld heat treatment (PWHT). In the Eurocode equivalent, EN 13445-4, it is stated that "Heat treatments after cold or hot forming, shall be carried out in accordance with the appropriate standards or data sheets or other specifications and shall include normalising, normalising plus tempering, quenching plus tempering, annealing, solution annealing." Have I missed something, or is this correct? For clarity: I am concerned with the base material, not welds.
