electrical429
If you order high voltage SF6 indoor metalclad switchboard comprising several panels does it arrive on site from the manufacturer as a whole switchboard unit or as separate panels?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Vacuum breakers do not imply SF[sup]6[/sup] insulation.The board is equipped with vacuum circuit breakers. Therefore busbar chamber is sf6 insulated.
