slickdeals
- Apr 8, 2006
- 2,266
The title of my post says it all. Please see attached sketch.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
.ACI 318-11 said:...should only be used when the shear force component parallel to the reinforcement produces tension in the reinforcment...when alpha is greater than 90 degrees, the relative movement of the surfaces tends to compress the bar and equation [whatever] is not valid
slickdeals/OP said:The original construction joint was shown perpendicular to the axis of the column. Our contractor friends thought we were crazy and put it horizontally.
