I have a problem with a dominant velocity peak at 6 times the rpm. What symptom does this indicate. This peak is on the NDE of a 400 kW Booster fan. The fan uses journal bearings. The DE of the fan shows 2 times rpm vibration but on the motor DE there is no indication of 2 times which would point to misalignment.
I need help with the 6 times component. And also whether taking measurements across the coupling should both have 2 times component to point to misalignment. Thanks.
