don't find ifort.exe when abaqus run the job
21did21
31
0
0
BE
Hello world,
i have a job with a subroutine, when i run the job abaqus say:
"Error in job AAA: Problem during compilation - ifort.exe not found in PATH."
i have search in this forum and i find this solution:
"Assuming you have administrator rights:
My Computer->Properties->Advanced->Environment Variables:
-in the "System variables" list locate "Path" variable
->Edit-> add the path to the folder were the "ifort.exe" has been installed. (e.g. "C:\Program Filed\....\BIN")
You need to separate the new path with a ";" from the other paths.
->OK->OK->Apply->OK"
but i have try this with this path:
E:\Program Files\Intel\Compiler\11.1\048\bin
and it don't work
do you say how i can resolve this problem ?
Last time I checked it is possible to get older versions of the intel fortran compilers from their website if you've already purchased a newer one. You might find a compatible version for abaqus 6.9 on there.
21did21, you will find enough challenges using Intel Fortran with Abaqus, let alone using another free equivalent of Intel Fortran. Try to get Intel Fortran if you can. All the best.
