millsjj
- Oct 19, 2011
- 12
I am currently designing a pressure vessel system for hot water with a max temp of 99C and operating pressure of 160psi. The part is shaped like a donut with wholes through one face to allow for hot water piping to be welded as this unit will be part of an outlet manifold. I am double checking the strength calculations as this is a part I have inherited and is not my own design. I am wondering the best way of checking this part as it does not fit in well with the standard ASME pressure vessel calcs.
My approach thus far has been break the part into two components, the outer and inner tube. I have treated the outer tube as if it is a standard pipe with internal pressure and used standard ASME calcs to ensure strength. I have then treated the inner diameter as if it is a standard pipe with external pressure acting on it. I feel like this should satisfy the criteria but I would like to see if anyone else has some advice as I wouldn't consider myself an expert on all things ASME.
I have attached a drawing below to give an understanding of the geometry.
