HDStructural
- Apr 24, 2024
- 120
At my new company (heavy industrial industry), I have been tasked with updating our general notes. Our steel general notes require that all shear connections be made with double angles and that shear plates and single angles must not be done. I understand the logic of not wanting a single angle but I don't see the issue with a shear tab. To clarify, I am not referring to any connections with crane runway beams or girders, just a standard shear connection for a typical beam, which may support equipment and live loads up to 500 psf.
I haven't found anything in AISC DG 7 or AISE Tech Report 13 forbidding shear tab connections.
Does anyone know why this would be required or if it is a code requirement somewhere?
