Double Throw Switch 1
Thunter78
1
I am a mechanical engineer by trade and have been learning more and more of the electrical side of things. I'm currently working on a project and hope someone with more experience can make sure I'm at least headed in the right direction.
I have two electrical panels, A and B, that are both capable of providing three phase 460V power. Both of these panels do have adequate motor protection branches. I need to power a 15HP motor from one of these panels, but never able to connect power from both.
We use panel A most of the time, but occasionally need the soft start capabilities of panel B (we cannot use a soft starter when operating with panel A, else I would only use panel B). Right now we have to rewire power to the motor every time we need to change panels, which is slowing us down. I have been trying to find what I need and think something like this will work perfectly:
Before I spend a few thousand on double throw panels, can anyone confirm my idea or think of a better way?
Taylor
The big issue I have noticed with IEC is the contactors go up in smoke if they bounce for any reason such as a motor start on a system with weak generators.
Is that what I call "Machine Gunning"?
The contactor pulls in.
The voltage drops.
The contactor drops out
The voltage recovers.
The voltage drops.
The contactor drops out.
Rinse and repeat.
That will kill a NEMA contactor as well.
Bill
Ohm's law
Not just a good idea;
It's the LAW!
For sure, but the NEMA stuff is much more tolerant and much easier to replace contacts on. Even worse when they use NEMA 1 equivalent enclosures in spaces that should be using NEMA 12. Thankfully we don't operate that boat any more. It was a steaming pile for a whole lot of other reasons too.
