Gents,
Suppose having Double walled Storage Tanks containing refrigerated Propane (-47°C) at Atmospheric Pressure. Nitrogen blanketing NOT an option.
My question is regarding the thermodynamic behaviour of propane inside such tanks? Is this correct to assume that when the tank is partially empty, the empty half of the space contains vaporized propane? If so, upon refilling this partially empty tank with more liquid propane, what happens to the vopor at the top half?
Does it turn back to liquid phase upon rising of liquid level and increase of pressure?
Does this system require a relieving device? If the relief system is a must, does it absolutely have to relieve into a closed off piping system or relief tank? Is venting into the atmosphere an option for propane?
thanks a bunch
drno
thanks a bunch
drno
