_Conky
- Mar 12, 2024
- 6
Not a lot of experience with older brick/block walls. Existing 2 storey 40+ yr old house all walls as 4" brick exterior with 4" block backup, with bond bricks turned every 7th course. I believe that this is considered as an 8" masonry bearing wall...not 4" load bearing block with 4" veneer. The building depts around are extremely quick to call out 'brick veneer' can't be used for connecting or supporting any load whatsoever, no matter how miniscule. I don't think I am off my rocker in coming back at them that this is NOT brick veneer, but in fact 8" solid masonry bearing wall. Opinions or experience with this? Thx.
