VVang
- Jan 30, 2024
- 7
Hello, I am struggling to find an example of how to design a doubly reinforced retaining wall. I tried analyzing the structure as a 1' wide beam but due to the 12" thickness of the wall I keep getting a very small As required and a very small a. Trying to use the doubly reinforced design method for beams, this causes my compressive strain to go in the negative because my d' is larger than c. Does anyone have any tips or recommendations?
Basically, I want to design a doubly reinforced retaining wall that is 12" thick. From my analysis I can use #5 @ 12" and it will satisfy, but I want to to analyze if I can use a lower rebar size (like #4@12") if I reinforced it on both sides. Trying to find out how to properly analyze that. Any help is appreciated, thank you.
