If you eject the 2.5" HDD + case USB 3.0 in Windows 10 and then hit the HDD case with your hand, will it damage it and generate bad blocks? Did the shock move the HDD on the table?
Did you actually see the notification that it was safe to remove the disk? I find that my Windows seemingly likes to hang on to my disks and often have to shut down the computer to get "clean" eject".
If you didn't see the notification, then it's possible some data got corrupted. Or, it's possible that the disk was still spinning when you hit it.
TTFN (ta ta for now)
OK, then it might just be coincidence; I once ejected a drive at the airport, and accidently flung it about 5 ft onto a counter side and the floor, without any issues, but YMMV.
