Doubt - Material used in the manufacture of nozzles in the pressure vessels according to ASME VIII -
pesquisador
Good day,
In Which chapter or (UG) standard ASME VIII - Div 1 says the nozzles must be made of metal bars. And never sheet metal. What page? Please. UG - 14?
Thank you.
UG-14 describes limitations on use of rods and bars, it states nothing about nozzles.
Look at UG-5 through UG-8 for materials applications.
There is nothing wrong with using rolled sheet steel to fabricate a nozzle. If you are referring to gauge material, see UG-45 for minimum nozzle thicknesses.
And UG-16 for minimum material thickness.
Mike
Good afternoon,
I could use tubes to manufacture nozzle, instead of sheet metal and bars metal?
If yes, I would use tubes,because it will be more economical. Not need machining.
Thank you.
pesquisador, tube, pipe, plate / sheet, forgings, castings, bars, shapes and even non-metallics may all be used in construction of pressure vessels subject to the various relevant provisions of the Code.
Mike
