Downcomer Welding 1
PHR_BR
Industrial
Dec 3, 2019
3
Where I work there is a water tube boiler, I noticed that the welds of the water wall tubes to the downcomer do not have full penetration.
Wall tubes 2 "
Downcomer 6
I am not an expert on the subject, but when reading PW-9, it is understood that these welds need full penetration.
Should I contact the manufacturer or is there anything to fear?
I will try to attach an image.
Thanks!
If you have a concern, contact the manufacturer and include the specifics of the boiler. You could include a couple of photographs as you did here.
Best regards - Al
These are ok. The ends are rolled originally (as new) and only welded as a repair when there is a rolling leak. Check the maintenance manual for more info.
DHURJATI SEN
Kolkata, India
