Downloadable Assembly File...SW10
dpsoccer12
17
0
0
Hey,
I have been searching the last 20 minutes for a way to create a downloadable assembly file for a website. The catch is that I don't want the person to be able to expand the assembly tree and be able to reverse engineer the parts. Any way to make this happen?
Thanks,
Jake
download.aspx
Be warned that any opening to the interior will expose the interior faces, and they will also be saved.
Openings will need to be "capped" before saving if that poses a problem.
Ultimately we would want our customers to be able to take our part and place it directly into their CAD model. That is why we are wanting to be able to provide the part, but not be able to have them edit it. This is why eDrawings doesn't really work for this case.
Suppress all internal parts in the assembly prior to saving out as a surface part. Alternatively, save out as a solid part and then open that part... do some extrudes to fill it in or some cuts to remove proprietary details. Save that out as a parasolid... then re-import it. Now you will have a defeatured solid part.
Neither solution is "automatic".
-Dustin
Professional Engineer
Pretty good with SolidWorks
