draft check
troy06
53
I am using Wilfire 2 and I often draft check parts for moldability.Is there a way I can select all of the surfaces of the entire part rather than each surface individually?
_ Use the Selection Filter, or
_ Click RMB to cycle thru available choices, or
_ Hold RMB and Pick From List
If you pick the part node (i.e. the name of the part at the very top) in the model tree, you will select the entire part.
how can i reload a saved map key to another computer.
sanket
please do not ask a completely unrelated question to the original post.
first search the forum for topics on mapkeys (there are many) and if you cannot find an answer, start a new topic.
