  • Congratulations IFRs on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Drawing background color......................... 2
CAD2015
Computer
Jan 21, 2006
1,993
I know how to change the background in 3D modeling.
How about in 2D drawing?...................
Thank you!
Type OPTIONS in the command line and press Enter.
Go to the Display tab.
Click Colors under "Window Elements."
Choose 2D Model Space from the Context dropdown.
Select the desired background color.
Click Apply & Close, then OK.
www.framosfabrications.co.uk
If your drawing is currently using the "monochrome display" option, go to preferences -> visualization -> color -> drawing layouts. In this dialog, you can change the foreground and background color.
If your drawing is NOT using "monochrome display", go to preferences -> background, choose a new color and OK the dialog.
Cowski,
Thank you!................
Right-click the "drawing" in the part navigator when you are in Drafting to toggle "Monochrome display".
