jeff97070
- Feb 14, 2013
- 52
In the custom properties I add the description and all the other items and they populate the title block correctly.
When I create PDF files of my drawings doing Save As under the File Menu and create a PDF file
and print it out the drawing description information does not show it's gone.
I have found when this happens and I open the drawing and do edit sheet format and double click on the description information "Bracket, Top" and click in the screen and do edit sheet format and create another PDF file it prints correctly, HOW STRANGE.
This is only happening to my A2 size format and none of the others. I have recreated and $PRPSHEET:{Description}over and over and saved it off but it will not print with the description showing.
Any advice will be appreciated.
