Drawing goes out of date upon saving.
BDD0203
I am currently running NX 8.0.3 and I have a drawing that goes out of date every time I save it. The only part that goes out to date is the "drawing" and "Sheet "sh1"", all views associated with sheet 1 have green checks next to them. This is a 1 sheet drawing. This occurred after updating the detail component to the latest revision. The only way to temporarily get the drawing to say up to date is to click the sheet to update. If I select the drawing to update it will not update. If I reopen the drawing it will still be out of date and a couple of crosshatching will be browned out but other wise nothing else gets browned out. I've gone in and deleted the crosshatching and this still doesn't help.
Any help would be appreciated.
If you partially load your parts try fully loading them (in the assembly load options) and see what happens.
Are you on Teamcenter ?
Jerry J.
UGV5-NX1961
I was able to find the fix. I had a dependent view associated to a section view. Since it was dependent view it was treed under the section view that was showing as up to date. Once I expanded the section view it showed the detail as out of date. I converted the detail to an independent detail view and updated. After this I was able to update the the entire drawing and save accordingly.
thanks for the update, very interesting
Jerry J.
UGV5-NX1961
