Drawing material callout: "material XYZ or Eq." 6
just_some_shmuck
For years, my company (consulting engineering) has included "or Eq." in drawing material callouts (IE "Material: ASTM A36 or Eq.")
Is this wise to do?
How will a fab shop interpret "equivalent"?
If I happen to suffer from momentary stupidity and specify a tube made from A36 I am fine if they substitute A500-B. If I specify a C-channel as A36 and they substitute A992-50 I am OK with that too. If I specify A514-B and they substitute A36 (much weaker), then I am NOT OK with that.
What are your thoughts on this?
Here's a link to a Bill of Materials for a heat exchanger prepared by a reputable manufacturer that's also an ASME stamp-holder:
The last three pages are the BOM. As you can see, every pressure-containing component a the specific ASME material grade called out, but there are also a number of generic material call-outs like "STN.STL", "304 S.S.", and "STL."
While I don't agree with their use of "STL." for the lifting lugs I think this is completely reasonable for the components that don't see any appreciable loads. For corrosion purposes the tube bundle components exposed to the shell-side fluid need to be 304 stainless steel, but no specific material grade is specified because it doesn't matter.
I've reviewed many BOMs over my career and I don't recall ever seeing one that didn't use a few generic material call-outs.
-Christine
