Drawing question - Dimensions 5
JakeyTGS
Automotive
Nov 10, 2023
I am looking for advice regarding a drawing I am currently working on.
How could I annotate on the drawing that the dimensions on the left pillar are the same as the right pillar?
I was using the TYP abbreviation next to the dimensions however I read that this is no longer used as a standard.
Is there any other way of doing this or do I need to add the same dimensions on the opposite face of the drawing.
You could simply extend the dimension lines to the elements on the other side.
Is this a case of Continuous features?
Because if it is, then showing the extension lines do not indicate a CF. Either a number like 2X or the CF symbol should be used.
Thank you all for your feedback. I Appreciate your help.
