Drawing view from part body
Alan Lowbands
Aerospace
May 17, 2017
274
GB
Could anyone help me with this problem.
I'm trying to run a macro that will select a body in a part and drop it onto a drawing sheet.
I've got it to work to a small degree with bits of code cobbled together but I can't find a way to let me select the face I want for my view.
any help as always would be really appreciated.
code I have is below
regards
Alan
Language="VBSCRIPT"
Sub CATMain()
Dim partDocument1 'As Document
Set partDocument1 = CATIA.ActiveDocument
Dim part1 'As Part
Set part1 = partDocument1.Part
Dim oSel 'as Selection
Set oSel = partDocument1.selection
Dim Filter(0)
Filter(0)="Body"
Dim F_Body 'as object
F_Body=oSel.selectelement2(Filter, " Select Body in which you want to add", False)
Dim bodies1 'As Bodies
Set bodies1 = part1.Bodies
Dim body1 'As Body
Set body1 = bodies1.Item(oSel.item(1).value.name)
Set documents1 = CATIA.Documents
Set drawingDocument1 = documents1.Add("Drawing")
drawingDocument1.Standard = catISO
Set drawingSheets1 = drawingDocument1.Sheets
Set drawingSheet1 = drawingSheets1.Item("Sheet.1")
drawingSheet1.PaperSize = catPaperA0
drawingSheet1.Scale = 1.000000
drawingSheet1.Orientation = catPaperLandscape
Set drawingViews1 = drawingSheet1.Views
Set drawingView1 = drawingViews1.Add("AutomaticNaming")
Set drawingViewGenerativeLinks1 = drawingView1.GenerativeLinks
Set drawingViewGenerativeBehavior1 = drawingView1.GenerativeBehavior
drawingViewGenerativeLinks1.AddLink body1
drawingViewGenerativeBehavior1.DefineFrontView 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000
drawingView1.x = 594.500000
drawingView1.y = 420.500000
drawingView1.Scale = 1.000000
drawingViewGenerativeBehavior1.Update
drawingView1.Activate
End Sub
the line bellow define the H and V vectors for the view
Code:
So in order to control this you need to ask the user to select a planar face using SelectElement2 and filter and get some directions from the face. This is where you will have to be creative... You could use theMeasurable on the plane and get first and second direction... please check V5automation.chm file in your code/bin/ install directory
Eric N.
Thanks itsmyjob,
I'll have a go :)
If the parts hadn't been on the component axis it wouldn't be a problem but the views are coming in like an iso view :)
I'll try and sus it out
