PAK_ENG
- Jul 20, 2020
- 12
Hi there. I am new to bridge design and would like some assistance. I am designing a multi column bridge pier with continuous footing supported on drilled shafts. I am using RC Pier and hand calculations in my design. I have designed the cap, columns, and footing and am moving on the drilled shafts. RC Pier does not design drilled shafts with footing, only if they are directly supporting the columns. So I am a little stuck on how to do the drilled shaft design. I am using FHWA-NHI 18-024 Chapter 12 as a guide. I have calculated the loads (Mxx, Mzx, and axial load) at the center of the footing, but how would I resolve the moments to find the Mu at the top of each drilled shaft? Also, any free programs that do drilled shaft design or generate interaction diagrams for circular columns based on AASHTO? Any assistance is appreciated. Thank you!
