drilling steel pipe - help please !
airtight
Marine/Ocean
Dec 14, 2003
22
0
0
AP
Tomorrow I need to drill approx 20 x 2 1/2" (63mm) diameter holes through the side of a 18" diameter steel pipe.
The holes are to take pins. I have thought of two ways to do this -
a) magnetic base type clamp on drill with a 2 1/2" cutter.
this would be the ideal way but the pipe grade is x52 steel , i think it will be to tough for the drill at that large diameter. steel thickness is 7/8"
or b) flame cut the holes and weld in machined bushes. A bit more work by the sounds of it having to machine all the bushes.
any ideas on how heavy going it would be drilling it?
i once drilled similar sized holes through 1/2" sa 516-70 and it bluntened the new cutter immediately. i dont think x52 is quite as tough as boiler steel though.
any help would be very gratefully received. thanks neville
Use a STRONG mag or air powered drill, clamp the drill to the pipe and use a long lever arm. There are special coated bits. They look like milling machine cutters, about 3/16" thick and will go through your pipe like butter. I'll try to remember what they are called.
Why not hold the pipe down on the bed of a radial arm drill press, mounted on Vee blocks? Then you can simply drill a pilot hole and go in with a 2 1/2 diameter spade drill.
The pilot hole can be something like 1/2 diameter, center punch the pipe OD at the desired location. This will ensure the drill doesn't skip, wander off location.
Just a thought.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
Thanks for the replies. The pipe is 45 feet long and weighs approx 6000 lbs, and there are 2 to be done. Each with approx 20 holes. The main problem i have with these cutters is speed and cost. The last time i used them as i have said was on boiler plate and it went blunt after probably one hole.
I know x52 is a high yield, perhaps not as high as 516-70 boiler plate, but i am concerned that i could waste over $1000 of cutters and a lot of time. we are doing the job outside so dont have a radial drill, that would have been ideal!
How about a combination approach. Plasma cut the majority of the hole, then clean up with the drill.
[cheers]
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
I agree with unclesyd and MikeHalloran - look at a Hougen magnetic drill and their annular cutters.
Cory
