Driving me insane " marks and Chr(34)
nick262b
25
Hi guys,
So this is driving me insane I have a macro which is exporting to a text file and I need the first line to be:
<ProjectInput xmlns="
I have tried the following codes with the following responses:
As expected
Cells(1, 1).Value = "<ProjectInput xmlns=" & " & ">"
gives
but when I try to add the ""
Cells(1, 1).Value = "<ProjectInput xmlns=" & Chr(34) & " & Chr(34) & ">"
gives
"<ProjectInput xmlns=""
Cells(1, 1).Value = "<ProjectInput xmlns=" & """ & ">"
gives
What's going wrong? (ps ignore the hyperlinks there not supposed to do that)
Thank you all for your help!
Kind Regards
Nick
Have you tried using a single quote [ chr(39) ] instead of a double quote?
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
This works in the worksheet:
=CONCATENATE("<", CHAR(34), "test", CHAR(34), ">")
TTFN
faq731-376
7ofakss
Hi IRstuff, yeah I know its strange I dont understand why its putting in extra quotation marks (especially at the front?) when I program it in the VBA :S I really dont want to go through and manually change hundereds of files!
Cheers Nick
The forcing of the second quote prevents the ambiguity of how to match up the quotes.
If the line were to read as follows:
"<ProjectInput xmlns="[ignore][/ignore]">"
The ambiguity is whether the quote that comes immediately after the equal sign is to start a second quote or to close the quote that begins the line. Is this:
"<ProjectInput xmlns=" & "[ignore][/ignore] & ">"
or is it
"<ProjectInput xmlns= & "[ignore][/ignore]" & >"
The ambiguity is resolved by using two consecutive quote to signify that the second interpretation is correct.
"<ProjectInput xmlns=""[ignore][/ignore]"">"
However, it's much easier both to code and to read by using double quotes on the outside and single quotes on the inside, or vise versa, single quotes on the outside and double quotes on the inside.
"<ProjectInput xmlns='[ignore][/ignore]'>"
Good Luck
Wish we could edit - there is an extra quote on the fifth line, right in front of the http. That line should read
"<ProjectInput xmlns=" & [ignore][/ignore] & ">"
Good Luck
What about this:
Code:
Cells(1, 1).Value = "<ProjectInput xmlns=""[URL unfurl="true"]http://tempuri.org/ProjectInput.xsd"">"[/URL]
or, if you are concatenating 3 string variables, try this:
Code:
Dim strStart As String
strStart = "<ProjectInput xmlns="
Dim strURL As String
strURL = "[URL unfurl="true"]http://tempuri.org/ProjectInput.xsd"[/URL]
Dim strEnd As String
strEnd = ">"
Cells(1, 1).Value = strStart & Chr(34) & strURL & Chr(34) & strEnd
www.nxjournaling.com
Hi Guys thanks for the responses,
I tried using Cells (1,1) = "<ProjectInput xmlns=""
and as you say "" is essentially saying " as text so I would expect to yield
but it outputted "<ProjectInput xmlns=""
Cowski, I tried your code and it also still gave:
"<ProjectInput xmlns=""">"
It keeps adding the extra bits in red which I dont want.
I though that in general when defining a string the "" marks are ignored i.e.
Cells (1,1) = "string" would give an output of string not "string" so I dont understand where they are coming from.
What version of Excel are you using?
I tested my code examples in Excel 2010 and the output to the cell is in the format you wanted (I have not tried exporting these values to a text file).
Hi Cowski,
I am also on excel 2010 just checked and yes in the actual Cell it reads correct as:
somehow when exporting my worksheet as a text file its adding extra " marks ?
The relvant code for exporting the worksheet is essentially:
Dim ws As String
Dim Output As Workbook
ws = "name of worksheet"
Worksheets(ws).Copy
Set Output = ActiveWorkbook
Output.SaveAs "C:filepath\" & ws & ".extension", xlTextWindows
Output.Close SaveChanges:=False
Cheers,
Nick
The export function is putting the outer quotes around the entire string because the cell contains a string. And because there is a quoted string within that cell, the inner string quotes are being doubled to avoid the ambiguous problem described above.
Good Luck
