I need to size a vertical separator for a reciprocating compressor with a mist eliminator. The inlet presure is around 15 kg/cm2g and the outlet 38 kg/cm2g. The gas have a higher content of hidrogen 92%.
I need to know, What is the maximum droplet diameter recomended to avoid harm in the compressor?
Thanks in advance.
Best regards,
FCS.
Thanks in advance.
Best regards,
FCS.
