Hi All,
Would really appreciate any advice on cutting 2.4mm thick (13g or 0.093") galvabond sheet. Im not sure if you call it "galvabond" or some other similar product name,in the States, but just to be clear, what I am talking about is a hot dipped zinc coated steel made up of: Galvabond G2 steel, a hot dipped zinc coated commercial forming steel with a spangled surface. Am getting further and further behind on our production requirements so am desperate for help.
Regardless of the settings I change in terms power, feed rate, frequency, nozzle gap, or focus I cannot achieve a consistent dross free cut. In some directions it cuts clean and then it will not in cut clean in others, but even this is not consistent. I have tried using both Nitrogen and shop air gasses, getting slightly better result with air but blackened edges. The nozzle is centered and lens is brand new. Am using 5" lens, 2.5mm nozzle. I am not getting this issue with other materials such as stainless steel. I am left to ponder if this could be just that this material is just a bitch to cut or if we have other issues which may need addressing such as mode alignment or mirror issues. As our machine is due for service, we will soon getting new output coupler, mirrors etc, so will retry again after that.
if any one is cutting this material sucessfuly on Amada FO3015 or similar, would appreciate the settings you are using so we can try them.
