dry air humidity when pneumatic test 2
erkuts
Petroleum
Dec 8, 2016
21
What dry air humidity value must be before pneumatic test after hydrostatic test ? In which API, ASME standart i can look ?
erkuts, I doubt you will find any such specified. How much moisture can your vessel tolerate?
Mike
I always took the route to calculate the min temp possible (from expansion) and then made sure that the air was dry enough to prevent condensation from forming.
