dual drainage model in swmm
julsmed
Marine/Ocean
Jun 8, 2018
1
what are the procedures to do a dual drainage model in swmm for flood zones using the sewer and drainage data for the area
Your question is too broad. What kind of dual drainage system you want to mode – for example, do you really want to model each inlet opening as a weir/orifice or just a simply manhole without flow restriction? Your budget and time?
Modeling a dual drainage system in EPA SWMM is very time consuming (still doable). You may want to use SWMM commercial version instead if they have some built-in features to model street inlets and gutter.
