Is there a rule of thumb on the hot deck capacity of a dual duct air handler? By that I mean is there a way to estimate how much hot water I need in the hot deck coil?
I have an exising dual duct system with no labels on the unit, HW pump, heat exchanger, etc. I will be making some changes to the steam system serving the hot water heat exchanger, so I need to determine how much heat is needed. I don't know water flow or delta-T, so that route is out. I don't know Cv on the steam valve serving the heat exchanger, so that route is out.
All I know is total CFM of the dual duct air handler, which is approx 35,000 CFM. From the looks of the hot and cold deck, I would guess that 1/3 of the air passes through the heat coil and 2/3 through the chilled; but, this is just a guess.
Based on this limited information, is there a way to approximate the amount of heat I need for this system? Does a typical dual duct system have a constant hot deck discharge air temp that could help me? If so, what is a typical discharge temp?
I am specifically interested in the summer months, so heating outside air should not be an issue. Any ideas?
