Hi, I'm about to purchase a fuel map device for my Hypermotard.
As background, the stock system has a single O2 sensor located after the two header pipes come together which provides a signal for closed loop feedback at low throttle and rpm. (<20%throttle, <5,500rpm). Above this range the stock system then goes to map based open loop.
My new device (Power Commander V) will not change basic process for low throttle operation, but will move the map base a little more rich. For higher throttle/rpm, the new device will have an autotune capability, whereas the signal from an additional O2 sensor(s) will be used to automatically develop the fuel map to a predefined air/fuel ratio map.
My question is whether it is considered that the fuelling needs of the two cylinders are likely to be different enough (due to temperature difference etc..) that I should have two sensors, one for each cylinder, or if one would be sufficient. My concern would be that if the difference between the fueling needs of the two cylinders is significant, with one sensor I'm running an average - ie one cylinder rich and one lean. Cons of two sensor setup are cost and complexity - I'd need three O2's - the stock one plus one in each header.
Thanks, Andrew
Thanks, Andrew
