Rajshrn06
- Jun 29, 2020
- 11
Hi
I have Reinforced Concrete frame building, where my beam's hogging moment is higher for gravity case than that for seismic case. If I undertake a ductile design in accordance with NZ seismic code (NZS1170.5), I am required to design my columns for the over strength of the beams capacity, which means that my column would have 4 times the capacity of that required by the actual seismic demand. This also basically means that I have 2 times the capacity of that required under elastic loads. Does this mean that I cannot adopt a ductile design as my columns capacity is in excess of the elastic demands? My understanding is that my columns would behave elastically so there would not be any post elastic deformation to even consider ductility in design.
