Dynamic forces exerted by a duct
pch1
Petroleum
Nov 6, 2002
58
I have posted this topic in the piping and fluid mechanics section, but I was hoping to locate a standard to refer to:
Can anyone help me locate a standard or similar that will guide me in determining the dynamic forces exerted by a gas flowing through a circular duct.
I do have access to most British and European standards, but only a few American standards if anyone is able to point me to a particular standard.
The conditions are:
Duct Size: DN1000
Duct Material: Carbon Steel to BS EN 10025 S275
Duct wall thickness: 8 mm
Flue gas pressure: -0.5 barg
Flue gas flow rate including water vapour: 32318 kg/h
Solids in flue gas: 1250 kg/h
The duct starts at a waste heat boiler (WHB) and feeds to an electro static precipitator (ESP). Between the WHB and ESP, the duct undergoes two directional changes of 45 degrees each in the Z plane, separated by a straight section of duct approximately 2 metres. There are expansion joints (Bellows) located at both WHB and ESP.
I did a quick calc on the forces exerted by the flue gas at one of the 45 degree mitred bends (Made of 5 sections) and have come up with 118 N in the horizontal direction and 49 N in the vertical direction.
Please note that these calculations may not be spot on as I have assumed a gas density of 0.657 kg/m^3 and a velocity of 18 m/s.
(I took a bit of help from this website: )
Thanks in advance
Paul Hearn
Without doing the calcs I would have thought the dynamic forces would be negligible relative to the static forces for the duct (ie due to duct weight)?
Marcoh
Yes the dynamic loads are small compared to dead and wind loads, but I was hoping to get hold of a standard so I could check my work.
What calcs would a person use for the duct in question?
I have used basic fluid mechanic calcs to determine the forces at the change of direction (i.e. Linear-momentum equation F=?Q(V2-V1)).
