I am running I-DEAS 9 on XP pro and am trying to mesh a model for ESC simulation.
Mid way through meshing the part, the following error appears:
'Insufficient Dynamic Storage, adjust the limits under Options, Preferences'.
When I go to Options, Preferences, Memory Usage, the following appears,
'Automatic memory tuning has been turned on.
To set parameters manually, change Memory AutoSetting to 0 in the param file and restart I-DEAS'.
How do I change the setting and where is this param file?
Am I looking at the correct option in Preferences?
Thanks in advance
Thanks in advance
