DZR TDC SENSOR ERROR FAULT
successwale
17
Please am running an engine MWM, Whenever i want to start the engine it keeps displaying DZR TDC SENSOR ERROR FAULT,
Wht could be the causes of this error
It seems self-explanatory; your Top Dead Center Sensor is not working, or not working correctly. That's where you start looking for causes.
You might get more and better responses in any of several automotive forums here, not the one dedicated to electric motors and such.
Mike Halloran
Pembroke Pines, FL, USA
Check the wiring to the TDC sensor. Check the connectors for looseness or corrosion.
Bill
"Why not the best?"
Jimmy Carter
And if it helps you to locate the sensor, DZR is an acronym for De-Zincification Resistant, a type of brass, often chrome plated, so it's telling you that it's the brass sensor on your cam/ crank / distributor shaft.
