qaalien
Nuclear
- Jan 9, 2006
- 6
In the Summer 1979 Addeda to the 1977 ASME Code Edition the Mn requirement for E7018 filler metal was changed from 1.25% to 1.60% max. My question is, has there been any code cases issued to allow the use of the newer filler metal to be used on code work prior to the change. The major filler metal manufacturer we work with will not make this filler metal to the older requirement.
