E71T-1 toughness
GRoberts
Materials
Apr 22, 2002
548
We have had fairly good luck with the particular brand of E71T-1 FCAW wire we use when testing CVNs at -50F after 1125F PWHT. Recently one of our customers specified an 1175F minimum PWHT temperature. After 1175F, the CVNs did rather poorly at -50F. (We also tested E7018-1 in parallel, and of course it did wonderfully) Anybody have any luck with low temp CVNs using a carbon steel FCAW electrode after 1175F or higher PWHT? We are just welding carbon steel, so most of the non-carbon steel electrodes we have used that would perform well at -50F severly overmatch the base metal with regards to strength, or have more than 1% Ni, and we have to meet NACE.
I have data after 1200 F for 3.5 hours, but only at -40F. They weren't great but met Code.
Thanks weldtek,
Any word on what your results were, and what brand/trade name you used?
The base metal was SA 516-70, 2" thick. Consumable was Hobart Trimark Triple 8, .o45" diameter with CO2 shield.
1/16" from Cap we had 16,20,& 14, 16.6 avg, and at 1/4 T from root we had 29,27,& 34, avg 30.
I'd be interested in knowing which brand you were having success with.
thanks,
John
Kind of ironic. We are also using Tri-Mark Triple 8- all 1/16" diameter and CO2 sheilding.
We have taken CVNs from the cap on a 3G test(3/4" weld on 1 1/2" plate) with SR at 1125F for 18 hours, and got 24, 31, 39 ft-lb at -50F. Also did 1125F for 8 hours on a 1G conformance test and at -50F we got 85, 68, 154, 60, 15 ft-lb (Per AWS- throw out high and low). We have had Tri-Mark also test several lots for us at the factory with 1125F PWHT and haven't had problems with -50F CVNS.
Our results with 1175F PWHT for 12 hours were 6, 10, & 4 ft-lb and 1175F for 1 hour were 5, 7, & 5 ft-lb(3G 3/4" weld on 1 1/2" plate).
Based on the difference between the 1G (heat input of 37kJ/in) and 3G (60kJ/in test at 1125F PWHT temp, we are going to try 3G with lower heat input to see if that will have any affect.
Weldtek,
In case you are interested in what happened, I was surprised by our results from the lower heat input test. Based on the dysmal result from the 3G test with about 60Kj/in, I did not think lowering heat input would make enough of a difference to get acceptable results. We did run 2 new plates at about 30kJ/in, and after 12 hr at 1175 and 1 hr at 1175, got results from 30-60 ft-lb (approx) at -50F. I was surprised, but it was a good surpise for a change.
GRoberts,
Thanks for the followup. Very interesting. Based on your earlier post I assume you're talking about values in the weld metal and that's a pretty dramatic difference. Just to confirm, did the values improve in the weld metal or just the HAZ?
Thanks,
HAZ values were still good, but actually decreased from the previous test with the lower heat input. Now that I have the data in front of me (doing it from memory last night)- the long heat treat weld metal averaged 85, and the short heat treat weld metal averaged 40.
Actual heat input (averages) were 35 and 57 kJ/in.
