A distribution board (DB) in the ground floor located inside an electrical room, is fed from a Sub main distribution board (SMDB) which is located in the same room.
In the earthing schematic diagram submitted, there is no earthing cable from the earth bar installed on the wall to the earth terminaion network.
There is an earthing cable from the SMDB to this earth bar, and there is a cable from the SMDB to the earth termination network.
Don't we need an earthing cable from the earth bar to the earth termination network??
The earthing system is TN-S.
Thank you in advance.
